KICKDOWN
doopdoop67
pacifica california
Hey guys I’m wondering if anyone has pictures of there lokar kickdown cable on both the transmission and carburetor. I don’t know how The cable goes into the kickdown arm on the transmission. And how do you route the cable. Pictures would be great! Thanks
Found these on the net but this is how I routed them before
1968-plymouth-valiant-lokar-kick-down-bracket-braket-attached-to-the-tailshaft-housing.jpg
You may need add a return spring too
Yep.
I just ran a light spring from the base of the stud that goes through the arm on the trans to that front cooler line.
Just enough to pull the lever and cable all the way forward under zero throttle.
Bouchellion has a nice one too that is an OEM cable from a 93-02 dodge truck. Looks factory and you can buy bracket for the throttle cable also.
