LA Head Gasket?
512Stroker
We are all here because we are not all there.
Freedom, MO
I have a .030 over 340 LA engine dated 1969, street application
So the bore is 4.070
I am looking to up the compression ratio from it's current 9.5:1 static
Current head gaskets are Mahle 3536SG compressed thickness - .045
I dont believe the sealing surfaces will hold a steel shim head gasket.
Does anyone have experience with a thin composite head gasket around .025-.030
Manufacture?
I used the 028 mr Gasket. It seems very forgiving. Several of guys I race with had good luck with them.
Surfaces were not a big deal, no leaks
It's my understanding Cometic will make pretty much whatever you want.
I would prefer Cometic gaskets but I dont know if my sealing surfaces a good enough. They heads have the stock factory surface and the block was squared and decked 3 years ago/6500 miles.
Tell them you have crappy sealing surfaces. You need a crappy sealing surface head gasket. They'll hook you up.
at 4.18 gasket bore
.045s are about 10.12cc
.028s are about 6.297cc
the difference is 3.82
on a 10/1 340engine at 4.07 bore, the swept is 706.754, so the total chamber size would need to be 78.53cc...
dropping that to 78.53 less 3.82=74.71 total chamber volume ,
and that would get you 10.46Scr
edited for fat-finger typing; I think I got it right this time.
