DionR
The OP has a old LA Offenhauser intake that he wants to bolt onto Magnum heads. That old intake doesn't have bosses for vertical bolt holes so the heads must be re-drilled to make it work. The Crosswind intake the guys are talking about has bosses for LA and Magnum bolt holes. (bosses for fuel injectors as well)
He also said he has a crosswinds intake in post #8 and then said it had a dual pattern in post #19 after stating it is an old offenhauser intake. I am confused because the OP has contradicted himself several times, not because I don’t understand the problems of mounting an LA intake on Magnum heads.
