Consider the weight savings 1 cent towards a dollar. Now do that all over the car. It adds up. It gets noticed. Once you start adding it all up.
But not that you actually point out something as if it were a fact, let’s dive into that aspect.
Thin walls. Can you personally prove. A nuke have thinner walls over a 340 or 360?
Can you personally prove that the decks of a Magnum have thinner decks over a 340 or 360?
How much deck thickness is needed for longevity, what ever longevity is in your head which you’ll kindly respond with an actual mileage minimum before failure.
Now the same with cylinder wall thickness.
**** Ford examples on a MoPar board.
But then again, I have had 340 tank with only a .030 overbore done. Glad I didn’t have to put any more money into that block besides the sonic check!
So much for “That’s one of the good year blocks, that’ll take a .090 overbore for sure!”
Wrong! I was left with a cylinder as thin as .030.
(OH! I just found another one of my sonic check papers. See below! Oooooooo, sooooo thick!!!!)
That is a very good question that an engineer should answer. Here on the I-net, I’m hard pressed to believe anyones word on why it exactly happens as a fact.
That maybe so, but can you prove it will happen for certain?
Look at this. 340’s can take a massive overbore?
