Mopar2
trying to figure out whats the widest tires I can put on a 68 dart with a 8.75 rear end and stock wheels so they dont hit the fenders or leaf springs
If you have the stock wheels (like you said in your post), none of the above mentioned sizes will work.
Your stock wheels are more than likely a 14" x 4.5" so a 215-70-14 would even be a bit big.
I would stick with a 205-70 or 205-75-14.
If your car is a factory 340 with the 14 x 5.5" wheels, you can go a bit wider, like the 215-70-14 I mentioned.
Yes its still on the stands. Those are suppose to be the increased ride height caltrac springs. Even if the tire does go into the wheel well i dont see it being a problem. it appears that there is plenty of room.That looks pretty nice but isn't that at full axle droop? What's it look like if you put the stands under the axles?
by stock wheels I mean stock wheels that came on a 68 dart, I have 14" wheel i think 6" wide currently with mickey thompson indy profile f70's but have a extra set of stock real wheels and wanted to put the largest available slick on that will fit under my car with NO modifications so I can run it at the track. so far I think im going with a 7.70" slick I found on summits site and thanks for the help and further input would be appreciated
http://www.summitracing.com/parts/HKT-10742/
Hi everyone.I tried this set up on my 68 Dart they are 275/60/15 with a 15x7 rim and a 4 5/16 back space
Ok guys, I'm out of this one...... This thread makes me want to pull my hair out.
The OP has 14" x 6" wheels (More likely 14" x 5.5" ). How will a 275-60-15 tire ever fit on that wheel?
