1. Kllrbee
    Kllrbee Well-Known Member
    78
    51
    Jul 3, 2018
    Richmond IL
    Local Time:
    3:01 AM
    Hey guys,
    My steering is everywhere when I hit a bump or a curve in the road. Noticed the LCA bushing on pass side is shot. The torsion bar is sitting on the bottom of the opening. The drivers side not as bad but its going too. Would that be enough to throw the alignment completely off and cause all the "bump steer" issues.
    I know its not true bump steer and that term gets thrown around alot. Im just using it in a general sense here to describe whats happening.
    Ill obviously replace them regardless. Just trying to pinpoint the issue.
    Also good time to upgrade to PST 1.03 bars and 1 1/8 sway bar.
    Thanks
  2. 72bluNblu
    72bluNblu FABO Gold Member FABO Gold Member
    9,564
    3720
    Nov 28, 2008
    NorCal
    Local Time:
    1:01 AM
    That’s more than enough to throw out the alignment.
    And it’s not like it’s a static alignment change, ie, your alignment is wrong but constant. Wrong but always the same. With worn out bushings, especially LCA bushings, the alignment is constantly changing because the LCA’s are moving around with suspension input.
    You’ll have to replace those bushings before you can put an alignment on the car that will stick.
  3. 72Dart6pack
    72Dart6pack Harder Better Faster Stronger.
    3,102
    2156
    Feb 1, 2016
    Roseville Michigan
    Local Time:
    4:01 AM
    Just did a set not that long ago. Easy to replace. :)
  4. Kllrbee
    78
    51
    Jul 3, 2018
    Richmond IL
    Local Time:
    3:01 AM
    Yup, thats what I figured. Pretty obvious now that I think about it.
    I didnt even notice them cuz I was so focused on finding the slop in the steering linkage and BJs. Those are good. Stock steering box so not "good"...but normal.
    Anyways, glad I found the culprit. Time for some upgrades.
    Those LCAs look great brother. Nice job!
  5. 72Dart6pack
    3,102
    2156
    Feb 1, 2016
    Roseville Michigan
    Local Time:
    4:01 AM
    Thanks. :)
  6. 72Dart6pack
    3,102
    2156
    Feb 1, 2016
    Roseville Michigan
    Local Time:
    4:01 AM
    They were installed on this.
    • Like Like x 1
    • Kllrbee
      78
      51
      Jul 3, 2018
      Richmond IL
      Local Time:
      3:01 AM
      Sweet!
      Goin all out.
      Question for me now is what all I SHOULD replace now that I will have it all apart.
      LCA bushings are a given. Ive decided on the PST Torsion and sway bar. Might as well do UCA bushings as they are starting to crack.
      The BJs and all the steering linkage looks good tho. Should I replace the BJ's and TRE's anyways since they have to come apart?
      Will probly just go Moog with all that unless u guys have any recomendations.
      Thanks again
    • dukeboy_318
      dukeboy_318 Our Lives, Our Fortunes and Our Sacred Honor. FABO Gold Member
      32,850
      11375
      Jan 19, 2007
      la la land
      Local Time:
      4:01 AM
      I would. Far easier to do it once and be done then to do it multiple times. Plus, it’s svae your money and time on the re alignment costs. I’d get a whole front rebuilt kit.
    • ir3333
      ir3333 Well-Known Member
      4,276
      891
      Jun 1, 2008
      ontario,canada
      Local Time:
      3:01 AM
      if your ball joints and tie rod ends are good i'd leave them alone.Although a lot of the off shore stuff is pretty good now you never can be sure.You might be replacing them with inferior pieces?
      And if they are good why replace them?
    • 72bluNblu
      9,564
      3720
      Nov 28, 2008
      NorCal
      Local Time:
      1:01 AM
      If you haven’t personally replaced the ball joints and tie rods yourself recently, change them out. You have to pull everything apart anyway, you might as well change them now. If you don’t put a ton of miles on the car it may be the last time you have to do it. If you leave them in there and then have to replace them later you have to pull everything apart again and do another alignment.
      Moog’s quality has dropped off recently. I would still use the Moog K7103 offset UCA bushings if you have the stock UCA’s only because they’re the only offset bushings for the uppers and the additional caster you can get with those will improve the steering feel and handling. Beyond that I would avoid Moog. Proforged makes pretty much all of those parts, I’ve been happy with the quality of their stuff. I replaced a nearly brand new set of Moog lower ball joints that has a ton of play after only a few thousand miles with a set from Proforged recently and they were better quality.
      • Like Like x 1
      • 1975abody
        1975abody Well-Known Member
        142
        75
        May 27, 2016
        Texas
        Local Time:
        3:01 AM
        Agreed. I recently installed a set of Moog lca bushings,and instead of being a press fit on the lca pin, they were a slip fit. I mic'd the od of the pin, and they were within a half a thou of some other pins I had on the shelf. Had to knurl the pins to get a good press fit.
        The next set of lca bushings I bought were Pro Forged. I only needed them for the inner shell.I found that instead of the rubber being a friction fit between the inner and outer shell like the Moog, they were molded to the shells. Needless to say, it was a fight to separate them.
        So I am not sure how the Proforged molded bushings would hold up versus the traditional friction fit bushings. Would the molded be more likely to tear?
      • 72bluNblu
        9,564
        3720
        Nov 28, 2008
        NorCal
        Local Time:
        1:01 AM
        To be completely fair I haven’t used a rubber set of the Proforged LCA bushings.
        But based on how the rubber bushings are supposed to function I wouldn’t think so. There shouldn’t be any movement between the rubber and the shells, all the movement is taken up by the flex in the rubber. That’s why the LCA pivot pins have to be torqued at ride height. The rubber in the friction fit bushings doesn’t slide on the shells when they’re installed either. So I wouldn’t think it would make a difference either way. The fit between the LCA and the shell and the pin and the shell is more important.
      • Kllrbee
        78
        51
        Jul 3, 2018
        Richmond IL
        Local Time:
        3:01 AM
        So Moog went to shit huh?
        That sux. I used their bushings on a couple B bodies and they held up well. But that was years ago.
        Ill look around, but most likely ill just get the rebuild kit from PST.
        • Thanks! Thanks! x 1
        • dukeboy_318
          32,850
          11375
          Jan 19, 2007
          la la land
          Local Time:
          4:01 AM
          They shifted production to Asia
        • TrailBeast
          TrailBeast Slightly Twisted Member
          19,942
          6587
          Mar 11, 2011
          Arizona
          Local Time:
          1:01 AM
          My Dart would literally change lanes by itself if I ran over one of those reflectors they put between lanes on hiways.
          (LCA bushings)
          Did all the front rubber with PST poly and the 1.03 bars and that was that.
          Drives great now.
        • Kllrbee
          78
          51
          Jul 3, 2018
          Richmond IL
          Local Time:
          3:01 AM
          Thats what its doing. Pretty scary actually...not fun. Good to hear that solved it.
          Would you recommend the poly over rubber?
          Ive heard they feel "stiff" and can be noisy.
        • mobileparts
          mobileparts Well-Known Member
          158
          34
          Jul 24, 2011
          West Hempstead
          Local Time:
          4:01 AM
          MOOG bushings are manufactured with MOOG equipment in Mexico -- not Asia -- because or rubber disposal laws (the excess / leftover / waste)....
          Their quality is still the best -- and Mexico doesn't care what is thrown out (look at their whole country -- but that's another long - winded story!!!!!) while the U.S.A. does -- and "forced" MOOG to head to Mexico.
          • Disagree Disagree x 2
          • 72bluNblu
            9,564
            3720
            Nov 28, 2008
            NorCal
            Local Time:
            1:01 AM
            Sorry, but their quality is NOT the best anymore. Not by a long shot. Multiple members here have had issues with the diameter of the inner shells as of late, they are not toleranced correctly for the stock pivot pins. And the quality of the rubber isn’t anywhere near what it used to be.
            The quality control on their ball joints has been hit and miss for years. I got several that were either loose and sloppy right out of the box or overly tight. Heck I even got one that didn’t have any threads on the taper.
            Haven’t had issues like that with Proforged, or any of the other companies I’ve used to avoid Moog for the last few years. If someone else would make the offset UCA bushings I wouldn’t recommend any of their stuff anymore.
            • hemi71x
              hemi71x FABO Gold Member FABO Gold Member
              4,699
              1267
              Dec 22, 2009
              Rancho Cordova, CA
              Local Time:
              1:01 AM
              Yep, just had that exact thing happen to me with a pair of LCA's that i rebuilt, and sold to a member here on this forum.
              Bad "shell" around the rubber, in the lower control arm bushing, where the shaft presses in.
              My customer sent the LCA back to me, and i made it right with a Proforged bushing, and sent it back, and reimbursed him on the UPS charge.
              Ya, MOOG quality has gone down the toilet.
            • GMachineDartGT
              GMachineDartGT Senior Member
              1,504
              185
              May 9, 2006
              203 West Hills Road
              Local Time:
              4:01 AM
              Might want to consider delrin for guys wanting a step up in LCA material. It’s harder than urethane and is self lubricating so it’s quiet. They elimate the need for outer shells an inners too when used with my pivots.
            • kursplat
              kursplat FABO Gold Member FABO Gold Member
              1,610
              723
              Aug 24, 2010
              so cal
              Local Time:
              1:01 AM
              and they're nice to look at until you can get around to installing them. you need to put your website link in your sig so the new guys can find it wink-gif.gif
            • 72bluNblu
              9,564
              3720
              Nov 28, 2008
              NorCal
              Local Time:
              1:01 AM
              I love the Delrin bushings from BergmanAutocraft in my Duster. The only reason I didn't mention them here is because I personally think they're better suited for use with adjustable strut rods. The reduction in flex at the LCA bushing could mean more potential binding if the strut rod isn't exactly the right length. And the factory strut rods are anything but exact. In some cases it would probably be fine, but not necessarily all. Suspension components all have to work together, so if you take out flex and play in one area it means you probably have to address it somewhere else too.
            • Kllrbee
              78
              51
              Jul 3, 2018
              Richmond IL
              Local Time:
              3:01 AM
              Great advice. Im sticking with rubber and will go with either proforged as recomended here or the PST kit.
              Might start a new thread for this, but Im finding conflicting opinions about the PST kit. Some say their BJs are hit or miss and the customer service leaves something to be desired.
              I know there have been plenty here who have dealt with them, so some real world experience would be helpful.
            • 72bluNblu
              9,564
              3720
              Nov 28, 2008
              NorCal
              Local Time:
              1:01 AM
              I’m no help on that, I usually piecemeal everything and haven’t done much business with PST. Problem with kits is they don’t work all that well when your car has components from a bunch of different years and an assortment of aftermarket parts. Or mostly aftermarket parts like my car at this point.
              Not sure what brand ball joints PST uses either. Another issue with kits like that, you don’t always get a breakdown of where it all comes from.
              • Agree Agree x 1
