LCA pivot pin loose in bushing problem
Suspension, Steering and Chassis
  1. ClydeT
    ClydeT Member
    22
    25
    Dec 18, 2018
    SW Ohio
    Local Time:
    2:55 AM
    Went to press pivot pin in lca bushing Moog (K791) from Rock Auto but the pin just slides in. Measured both, the pin measures .810 but the bushing ID measures .813. My question is, should they always press in. Do I have bad Moog bushings, they are brand new. Thanks
  2. Plymouth 65
    Plymouth 65 Floorable Deplorable
    1,117
    1027
    Jun 27, 2016
    Mich
    Local Time:
    2:55 AM
    Most likely the pin is corroded/undersized. They should have a press fit into the bushing. 65'
  3. hemi71x
    hemi71x FABO Gold Member FABO Gold Member
    5,430
    1681
    Dec 22, 2009
    Rancho Cordova, CA
    Local Time:
    11:55 PM
    The quality of MOOG bushings has been very questionable, these days.
    I recommend bushings from Pro Forged.
    Rock Auto also has them.
    I too, had a bad fitting MOOG LCA bushing that i installed onto one of the control arms that i rebuilt for a customer of mine.
    When installing it onto his vehicle, the nut on the shaft wouldn't tighten down properly, due to the shaft "spinning" around in the bushing.
    Made it right with him, with Pro Forged bushings, from then on.
    Seems lots of folks are running into problems with the manufacturing of the new crop of MOOG parts, sad to say.
    • Agree Agree x 1
    • ClydeT
      ClydeT Member
      22
      25
      Dec 18, 2018
      SW Ohio
      Local Time:
      2:55 AM
      Think I'll return them and get something different. My pins are in perfect shape and measure .810 which is what they should measure. The bushings are probably just oversize a little. Probably should be around .807-.808 guessing. Thanks guys.
    • AJ/FormS
      AJ/FormS 68 B'cuda fb, Form S clone ... 367/A833/3.55s
      18,595
      6700
      Jan 19, 2014
      South-Central Manitoba,Canada, 900ftelevation
      Local Time:
      1:55 AM
      Are the bushings already installed or loose on the bench?
      My brand new pins were loose in the PST poly-whatever bushings too, after the install. That was 1999 and it doesn't seem to have made a difference.The T-bars keep them in there, but they just spin inside the bushings. They currently have over 125,000 miles turned on, but I haven't looked at them since about 2005, nor have I ever greased them.
    • 72bluNblu
      72bluNblu FABO Gold Member FABO Gold Member
      10,890
      5320
      Nov 28, 2008
      NorCal
      Local Time:
      11:55 PM
      With OE style bushings the pin needs to be a press fit into that metal inner sleeve. If it’s not, they’re junk.
      The requirements change if you change bushing materials, but even for the poly and Delrin bushings the pin should fit tightly into the bushing (tight slip fit). Any slop between the bushing and pin is slop in your suspension and will amount to a loose alignment. Plus wear out the bushings faster.
      • Like Like x 1
      • Ager
        Ager 72 Demon 340
        107
        21
        Aug 31, 2018
        Frederick Maryland
        Local Time:
        2:55 AM
        Looked at summit web site. A few peeps have had a problem with these bushings.
        Oversized, Undersized. Moog aint what they use to be.
        I just installed greaseable pivot pins and bushings
        PROFORGED 12010003 Greaseable Polyurethane Lower Control Arm Shaft Kit
        worked great
      • ClydeT
        ClydeT Member
        22
        25
        Dec 18, 2018
        SW Ohio
        Local Time:
        2:55 AM
        Checked the description on Rock Auto for this Moog bushing. It says the ID is .810 but apparently that's wrong. It's .813 on the ones I got. I think Moog probably isn't what it used to be.
      • 72bluNblu
        10,890
        5320
        Nov 28, 2008
        NorCal
        Local Time:
        11:55 PM
        You're not the first person to have this problem. There are a couple other threads about this, one that has pictures of the most recent Moog bushings compared to an older set. They're not the same. Not sure what happened, Moog may have moved production to a new factory and the specs are wrong on the new stuff. Not sure if you have a way to contact Moog, at some point it would be nice if they figured out their new bushings don't fit and correct the manufacturing line.
        • Agree Agree x 2
        • Demonic
          Demonic Well-Known Member
          1,332
          1051
          Mar 21, 2015
          Maryland
          Local Time:
          2:55 AM
          I had the same problem. I should have measured the bushing i.d. though. I just bought another Moog K791.
          MOOG Parts
        • Jim Lusk
          Jim Lusk Well-Known Member
          4,408
          752
          Mar 8, 2006
          Fresno, CA
          Local Time:
          11:55 PM
          This has been a problem for a while and well-documented here and other forums. It's why I won't buy anything Moog right now. I recently bought some old stock ACDelco professional from Rock Auto. I bought six and I think they had nine left when I ordered (so three left after my order). If those had not been available I would have bought the ProForged.
          • Agree Agree x 2
          • dodgy
            dodgy Well-Known Member
            122
            181
            Sep 25, 2019
            Australia
            Local Time:
            4:55 PM
            I've only run into this once here in Australia and they were that lose you could just about drop the pin in, not sure what brand they were as they weren't marked on the rubber like most are, having said that they were not moog, anyway the Supplier sent me some replacements that were ok, i now use Mackay brand that seem to be in spec.
          • GMachineDartGT
            GMachineDartGT Senior Member
            1,629
            274
            May 9, 2006
            Huntington, NY
            Local Time:
            2:55 AM
            I make my own pins and delrin bushings. They fit together perfectly as I've set the tolerances to do so.
            Bergmanautocraft.com
