swing69
fightin' socialism
I've always thought that 1 piece rubber bushing on the end of the LCA strut was cheezy. The stock - later with 2 pucks seems better.....and the solid / adj. one are trick.
1) There isn't a tubular sleeve in the early A rubber like the later 2 piece type, is there? I think there isn't.
2) What is the prefered methd for making sure the rubber is "squashed" the right amount? is using a 1 piece OEM rubber?
3) should I just use the K7040 2 piece design for the LCA strut? is it that much better?
thanks
thanks
