blue missile
I know somewhere there was a thread about adding water through the manifold to the back of the heads.This was something I was always going to do, but in the light of wanting to push the compression envelope on pump gas, I thought it would be helpful.
The original poster correctly noticed that there were two ribs in the way of the modification. That was easy enough to remady. The manifold was marked from the back with a gasket and some layout dye, drilled and tapped npt3/8". That was the easy part the next challange was to find the right combo of fittings to bridge the gap and clear the distributer.
The first attempt used all AN fittings including a tee but it didnt have the room. I made several trips and had a very patient parts guy at the speed shop help with a couple more configurations after I brought the manifold to him.
The final result was a combo of AN and barbed fittings. As you can see the clearance behind the distributer is very tight.
Hope this helps
Hope this helps
