74Dusted
Stock Piler of 340's
Here's an LD4B that's been collecting dust in the garage for a few years. I bought ages ago and ran it on a Small Block (318) D50 truck.
The Good :
Stock Ports
No Cracks
The Bad and semi-bad :
The Intake to Head Bolt holes were "egged" when I bought it, I guess either to install it on a 64/65 273 or on a set of heads that were milled.
Two of the Carb to Intake Bolt Holes were repaired (previous owner) by rethreading One Size Bigger. I didn't notice until recently, because it's the Right Front Outer and Left Rear Outer (AVS mounting holes) and I ran a Thermoquad (inner bolts) on it. However, I did pull the Spreadbore Adapter off and bolted one of my AVS's on, all the bolts hold firmly (though the Right Front Outer is kind of loose/sloppy at the very top/start of the threads)
It's located in Lewistown, Pennsylvania, 17044.
Asking $120 + Shipping
I'm including the Squarebore to Spreadbore Adapter (if it's wanted), the Thermostat Housing, Heater Hose Nipple, Bypass Hose Nipple, Temperature Sender and Vacuum Tee (or a plug if you don't need the Vacuum Tee)
The Good :
Stock Ports
No Cracks
