Let's do it!!! Mopar Motor Monday!
Mopar Performance crate 360.
Dang......so tired nearly forgot!
My virgin 68 318 I'm gonna build to a stroker!
Sitting in my garage waiting for money!
Jeff
Hey if that is a factory 1968 318, that will have the Valve Relief Flat Top pistons in it 9.2:1 compression right out of the factory in '68. Made 230 hp even with the 2bbl on it, put a 4 bbl on it and wake it right up.
I would be interested in those stock bore valve relief pistons if you really want to stroke your block. Thanks . . .
Mopar Motor Monday, here we go.
Put the valve train together on this '91 318 Roller engine I am building.
Primed the oil system, installed distributor drive gear, bolted down snd sealed the intake manifold, installed distributor. Puting the valve cover gaskets on tomorrow and bolt a coil onto the manifold and it is about ready for the engine run stand to fire it up.
So yeah have steel on hand here and next thing is to build up the engine run stand. Want to get them fired up, all tuned and dialed in on an engine run stand. Then they are ready to put to use.
Ready for Engine Run Stand Next
Just a little 'ol 273 with an Isky turbo grind cam and a sheet metal MPFI intake...nothin' special....View attachment 1715550265
Pishta's sheet metal intake
Now I am glad I asked about that "Red Mopar Small Block".
Really like what you have done there. This is what Hot Rodding is all about.
Come up with a new idea, and see it through to make it work.
Thanks for posting this up !
