CUDACOX
O.K. I'm most likely setting myself up here but go ahead! lol..I have broad shoulders and gunna be 48 the end of the month so I can take it! lol..Just want to know like many others what everyone thinks.. My build..318/402 stroker Indy kit,Eddie RPM aluminum heads gasket matched,RPM 7176 gasket matched.Roller rockers,Comp cams.XE274H-10.Here comes the kicker...I'm gunna run the 68/340 manifolds because I'm a stubborn old fart.I have after market stock type 2-2 1/4" exhaust,8 3/4"rear with 3:55 sure grip,255/60/15" out back,Having the factory 904 built strong,having converter built to engine,etc specs.Not sure on the carb yet.I have almost all parts to build so I don't want to buy different.What do you predict?? Thanks in advance..
