AdamR
Big Member
Im trying to put together a list of parts that work on these heads.
Valvesprings, Rocker,valve covers, valves. Anything that will interchange from other makes and models. My reason for this is because Im going to be swapping a set on my 340 soon. Im running a CompCams XE274H and Im having a real hard time finding valve springs.
Mopar sells the R/T spring. however this spring is right at its limits with my cam and may have coil bind and/or valve float problems. If I was running a XE268H They would work. However you need to swap to 2.2/2.5L retainers with these springs.
the Mopar "6062" spring also works with magnum heads but is to stiff for my cam. It also requires machining of the seat and a differant retainer. Anyone know what retainer to use with this spring ?
Another valve spring choice is to machine the seats to run LA valve springs. this would seem like the thing to do but again what retainers to use? You can't use LA retainers becuase the valve stems are 8mm
Ive heard that you can use CompCam beehive springs #26918 with retainer #772. Still looking to find out if the seats need to be cut to run them.
Rocker Arms
The Magnum arms Ive checked have the same part# as chevy arms. So you have plenty of choices there. You'll need 3/8" screw in studs and guide plates. I'll add part numbers later.
What about Stud girdles ? Anyone try running a set on magnum heads ? When I get my heads I'll measure the stud spacing. If its the same as the Chevy spacing they should work assuming the fit under the valve covers.
Pushrods.
Mopar sells a set of of push rods for converting LA to Magnum heads
Ive also read that Boss 302 push rods work. I'll look in to that some more also.
Valve covers.
You can use production Magnum or Mopar Performance covers.
Ive seen LA covers used also and this is what Im going to do.
Again Chevy cover work with alittle bit of filing the bolt holes.
Intakes. A few choices here.
Shell out almost $300 for a Mopar Perf. M1 single or Dual Plane or an Edelbrock AirGap.
Professional Products AirGap for around $175
Redrill your heads and use any LA intake.
So thats what I know about Magnum heads at the moment. Anyone have anything to add or comments ?
__________________
Rocker Arms
Pushrods.
Valve covers.
__________________
