Rice Nuker
Burn tires daily
I fabricated a rail from four 3" x13" angle iron and then welded chains on each corner and a a number of holes down the rail. Bolted the chains to 4 corner intake bolts with grade 8. Worked fine. Had the big haussy neighbor kid there for heavy liftin.
Took a solid 2 hours. The motor mounts have locating pins are sandwitched on angled frame perches. Had to "snap" the motor into the frame cradle by compressing the motor mount rubber in various ways.
