Lifter turning or not, he had to have had his high pressure double valve springs in there at first break in to totally destroy that lifter like that.
Being the new camshaft lobes outter edges are so sharp, they can actually cut you when working with them.
Eliminating any unforeseen problems, I take and sand back those sharp lobe edges with 240 grit emery cloth by hand prior to final cleanup and install of the new camshaft. Fussy and it takes time, but feel it's worth the effort.
If things happen to go bad, they are not going to chew like pictured above. Putting a lot less metal particles into a fresh engine.
Here is a well used stock 1974 318 cam with 100,000 miles on it and the lobes are starting to go flat. (probably from poor oil changes)
Lifters only showing slight cupping, but yes they are worn but not destroyed.
Running on stock single 318 valve springs by the way, and the lower lift original stock cam.
