GJSZ51
Is there such a thing. Fellow down here has one he says runs but unknown condition.
Is it worth grabbing up?
GJS
GJS
All small blocks since 1967 are lightweights. That's what LA stands for; Light A, A being the SBM engine designation.
Well you might ask, light as compared to what? Answer;light as compared to the earlier Poly-As.Beginning in 66 or 67, Chrysler made a bunch of changes to the polyspheric-As and gave us what we have had,well into the 80s, and with minor changes, into the late 90s and beyond.
As for snapping it up..................a 360 is only a few pounds more.
Yup. The "Poly" 318 is an "A" engine. Which might explain why 350/361/and later 383, and later 400 is a "B" engine
'Poly' are often nicknamed "wide block" which is a misnomer. The 318 A and LA blocks are VERY similar, and if you have the two bare blocks together, and don't know what to look for, you might have a little trouble telling them apart.
Yeah, the "wide" part of the poly 318 was the heads, not the block. Though the block casting has more beef to it, the basic dimensions are much the same.
What I don't get is why they shrunk the bore.
318 commando would of been an awesome engine
Yes get it before he figures out what it isOIs there such a thing. Fellow down here has one he says runs but unknown condition.
GJS
