mguner
How many is too many?
These are some of the cars that use the same rotors and spindles as the Darts and Dusters from 73 up that had the large ball joints.
[/IMG]
Correct, the spindles are a little taller between the ball joints but I have put them on both A and B bodies with good results. Somebody will probably jump in with technospeak about Ackerman angles and bump steer this and that but the things do align and drive fine without eating the tires.Spindles on F, M and J bodies (Aspens, Dippys, Miradas) aren't the same as A bodies - they might work, but aren't the same. Rotors are, though...
I thought I could get your attention DWhy not get a kit for the 10 inch drum spindles you have?
