Loose Nuts!
EvilScamp
Dalton PA
Noticed yesterday the left rear wheel one lug was gone and another was turned out and hanging by one thread,and the other 3 were a little loose!
I went around and checked the lugs on the other side and they were also a little loose!I'm running Cragar S/S wheels and never had this happen before,so now i'm just wondering if someone was screwing with it! :x
Today i had a small exhaust leak so when i checked it,it was leaking between the muffler and tailpipe connection.Reason:LOOSE clamp!
While i'm under there i notice the one bolt on the drive shaft is backed half-way out :shock: ! WTF!!! Put some lock-tight on ALL of them and put it back together.
Maybe my car is possesed and is slowly taking itself apart! :shock:
I thought Christine was supposed to fix herself, not take herself apart :lol: When was the last time you checked them and how often do get on it hard (probably every chance you get :D ) The shock from burning out and hard driving will loosen things up. The harder you drive your car, the more often you should be checking things. Or maybe that "Evil" name has something to do with it :geek:
sounds like my car. Everything is loose. I think Im affraid Im going to over tighten stuff and have it break so instead it falls off and breaks. :roll:
Craig you know me to well! :geek:
Guess i'll have to check them on a regular basis! :twisted:
