lost 1st and reverse in 904
barbee6043
barbee 6043
Shepherd, Texas ( SE Tx)
Friends 904 trans behind his slant. He wants to try to repair. Whats is the issue(s)????? Can he do it and he is not a mechanic!!
Could be the lever broke or backed off from the servo to rear band in which case transmission would not have to come out. I have replaced them between time runs at the track in a stacker trailer.
The last thing you typed is the key, “he’s not a mechanic”
So bring it to a trans guy and it could be fixable in the car. This is a common problem on these, but it depends what part failed.
Piston or strut failure, yes in car fix.
Broken band or linkage, no.
