Freezerman
I have a 72 Dart with 5.9 magnum and 904 transmission. It has a Cope valve body a few years old that has part throttle kickdown on it. I have never been able to get the part throttle to work but the full throttle was working with a BPE setup. I changed the 1-2 shift speed spring to raise the 2nd gear shift RPM. After that I can only get downshift if I preload the throttle pressure arm so far that I can't get full throttle. Any ideas on what I need to adjust for that or why I never had part throttle kick down?
