Yeah the pump turns just fine, I primed it for about 5 mins and it was holding 50 psi the whole time. I dropped the pan, took the pump off and cleaned/inspected it. I pulled the main caps one by one and they all look great. No signs of excessive heat damage. I also checked the # 1&2 rod bearing and they looked fine so I buttoned it back up( I know I didn't check all the rod bearings but after what I saw and the fact that the rod bearings furthest from the pump looked fine, I decided the others were most likely fine as well). It only ran, at max, 20 seconds after the pump failed. It was a late night for sure. But as always, one problem leads to another. Now I've got no spark. I appreciate the help everyone. I'm gona grab my ohmmeter and start this new headache.
