rustytoolss
I'm thinking of doing a "LOW BUCK" (if that's possible) small block project. I'm looking for input on what might be a good way to go. I'm open to a 318 or 360 (doubt a 340 is in the budget). An LA or Magnum (which ever is the most cost effective). I'm thinking of fuel injection/ because a carb for turbo use would cost a lot. I would probably try to get the factory electronics . Should be cheaper than a aftermarket FI system.
Would it be cheaper to start with a Magnum over an LA based engine ?
I know that this is not much to go on, but this is just in the planning stages.
As far as parts go. OEM salvage yard stuff, used, swap meets...aka cheap. Boost levels say 8-12 PSI. Something very streetable.
So if anyone can point me in the right direction, that would b great.
