mrose
Active Member
I need some help figuring out why I can't get a good charge going. Here's the set up:
68 cuda with a 69- 340 in her. Just totally redone. all new wiring harness's from year one. The alternator is new and when checked on a store machine tests good and at 14.5 volts out, it is a double field alt and I am only hooking up to the one "field" lead that fits the stock wiring connecter, this is what the manufacturer of the alt advised me to do and I even tried jumping the two which is another thing they had me try. The battery is good and I just replaced the VR. I have checked all the grounds and even double grounded the Alt and VR with separate grounds. Everything else electrically works on the car but the voltage at the alt and battery is around 12.1 and on a bat/charging system tester doesn't even get to the "charging area" on the machine. The gauge in the car does move back and forth as you increase the RPM's and put a load on it but as in the past before the rebuild if I drive it at night it is going to kill the battery and leave me stranded. Much of the reason I did the rebuild was to correct this issue and it seems it hasn't. The only thing really left in the "old" system is the original ignition key unit and the headlight switch which I can't see would have anything to do with this issue.
Please let me know if you need any additional information to make a diagnosis.
Many Thanks
Many Thanks
