glhx
my 76 318 has no oil pressure at idle. it is a mechanical gauge. upon rev the oil pressure goes up 10 psi for every 1000 rpm. im getting 40 psi at 4000. then t goes down to zero at idle. so far i dont hear any noise and the dip stick looks clean of metal shavings.
worn bearings
worn oil pump
stuck pressure relief valve
bad gauge
any thoughts on this
worn bearings
worn oil pump
bad gauge
