Lower Control Arms - A vs B
Early A-Body Discussions
  1. dodgedave68
    dodgedave68 Active Member
    34
    0
    Apr 27, 2011
    dallas
    Local Time:
    11:49 PM
    Are 64 A-body lower control arms the same as a non-sway bar 1969 B-body lower control arm - I cant find any difference in any of the measurements and views I take
  2. cosgig
    cosgig MoBro Inc. FABO Gold Member
    10,864
    3422
    Jul 20, 2008
    Pinckney, Michigan
    Local Time:
    11:49 PM
    If you look closely at the lower pivot shaft, you will see the difference. Although I don't have a B body one here, I'll explain the difference...
    The B body shaft has a longer machined flat before it starts to taper than the A body one does. I don't know off hand if the shaft is a different diameter or not, or whether you could replace the B body shaft with an A body one, but I know the shaft is machined different for sure. Maybe somebody else could chime in with an actual measurement of each shaft. That's all I can add, Geof
  3. cudamark
    cudamark Well-Known Member
    6,217
    34
    Mar 14, 2009
    San Diego
    Local Time:
    9:49 PM
    Yup, pivot shaft and the shock mount location are the obvious differences. Without a jig it's hard to tell about minor dimension differences.
  4. dodgedave68
    34
    0
    Apr 27, 2011
    dallas
    Local Time:
    11:49 PM
    dang guess I'll rebuild the A-body ones - THANKS!!
  5. Moparhead64
    Moparhead64 Well-Known Member
    165
    3
    Apr 3, 2011
    Jackson, MI
    Local Time:
    12:49 AM
    Well when I put the A body lowers on my brothers 68 b -body the lower part of the tire was kicked out, so the A body lower control arms seem longer than the B - bodys GO FIGURE
  6. autoxcuda
    autoxcuda Well-Known Member
    6,189
    501
    Apr 6, 2007
    Local Time:
    9:49 PM
    CORRECT. A-body LCA are longer by about 1/2". Also the strut rods will not interchange from A to B/E.
  7. oldkimmer
    oldkimmer FABO Gold Member FABO Gold Member
    10,453
    1296
    Nov 11, 2006
    Kindersley, Saskatchewan,
    Local Time:
    11:49 PM
    ...............Ya i heard u cant use the shorter B body 1s from Bill Reilley.......would make for lots of positive camber and caster though....maybe he can set us up.....kim......
