Lunati Voodoo Cams question
340_Scamp
Norman,OK
According to their website the Voodoo Series will work in 1967-present 318-340-360's. I currently have one in my LA block and want to know about switching it over to my 360 Magnum. Does this sound feasible? Also what lifters would the swap require? Flat tappet or roller?
The cam journal is the same in all the small block engines. So swaping in a cam doesn't have pitfalls of "What year do I have?" type problems or fireing order & counter rotation problems.
So yes, it is feasible.
On the problem of lifters, the style of lifter is also what style of cam you have/want. The Magnum engine uses roller lifters stock but can be re-equiped with a Hyd. or solid cam with the like lifters. You can not swap lifters around from cam to cam, or Hyd. cam to mech. cam to roller cam.
Trust me, it just won't work. The cams are ground to work with the lifters that are gound to work with that style cam.
The great thing could be that if you have a full roller engine now, the price of the cam is all your going to payout unlike if you just have a bare block and then need the lifters and everything else on top of it.
Just beaware if the roller cam needs a bronze distributor gear drive or not.
So will a new set of hyd. lifters just drop into the Magnum? Or would I need to do something to the block to make them work?
They'll drop right in.
You'll need longer pushrods if replaceing a roller cam.
You can order them off the shelf at any store. Proper length for a perfect set can be done easy by ordering a pushrod length cheacker. You can get them from Comp cams or Huges racing.
Custom sets are pennys more by the way. Worth the pennys.
Cool..thanks for the info! I have access to a push rod length checker, so I'm good to go there.
Good, then FYI on Hyd. cam lifters, you want the pushrod to depress the lifter by .050
