machining 273 crank for later 904 converter
65TerrorCuda
Albuquerque, New Mexico
Alright, so I'm looking at getting my crankshaft pocket/register/etc. enlarged for the later easy-to-find converter. I've seen two sizes listed for the bore, both 1.81" and 1-13/16" or 1.8125". Can anybody verify this? How much clearance is there for the converter hub?
And for anyone who's worked on a crankshaft, how do you hold it without damaging the mains?
All help appreciated, I sure don't wanna junk this crankshaft due to some rookie mistake.
Not much help, but im removing 904 that has smaller hub converter. When I put 340 in, I had to have a spacer/bushing made. I can get dimensions once trans/converter is out.
Much appreciated, but I'm trying to get away from the small hub. I've called 10+ torque converter places and I'm looking at minimum $850. I've got the opposite problem, later 904 with the 273. I should just go 340 and call it a day, I'm considering it.
I'm unsure the crank register is thick enough to do that.
This is my concern too, but I asked another member that's done it himself multiple times and I guess it wasn't an issue. Every crank is different though, so I'll have to take a close look once it's sitting on the bench.
Here's thread where I did the opposite, went from 340 crank to 273 converter. Might help?
Flex plate bolts witness marks on torque converter
Hey thanks! That's a great reference for sure! I enjoyed that read.
My plan is to borrow a converter and take it with me when I get the crank machined.
I had an early small block steel crank machined for the larger register. Cost $65 bucks 10 years ago.
What You are doing has been done, there are pics either here on FABO, or on the Slant Six Forum .org site. It works...
I will give that a look here soon, thank you!
Local shops have quoted 100-150 minimum for 1 hour. So long as it doesn't become a paper weight I'm happy with that.
Hope y'all are doing good,
You know what they say. Measure twice, cut once. But somehow I still always get it wrong.
So I got the crank register machined to 340 specs, handed over $150. Seemed like a good deal...
As I'm leaving, shop owner says, "it may not be perfectly centered."
Why would you leave a customer with a doorknob confession like that?
Did they machine the crank register in a lathe?
Not sure. I asked them this before they did it, the answer was it would be held by a fixture clamped around the seal journal at the back end, but nothing more detailed. The guy said he'd done it before without issue.
They have a few big lathes and I don't see how else they'd turn it.
If the crankshaft pilot was modified in a lathe, there is not much room for runout error.
Perhaps he was just being smug.
But it MUST be centered, or else it will tear the front pump bushing all to hell and then...more stuff. What a tool.
How would someone do that? The crank register is on one end that gets clamped in the lathe.
I'd think if you can't do the job, let the customer know. I'm going to lay the crank in the block and dial indicate the bore. If it's off by much I'll get a 4" stroker and mill the pistons. Lol
That's what I was gonna come back and recommend. Not the stroker part. lol
Mill ain't tall enough I don't think.
You can hang the crank off the side of the table to machine it.. But why would you...
Snout in the chuck, use a live center in the tailstock to support the flange end of the crank while setting up a steady rest... Remove live center & bore the damn thing..
And yes, now that it's done throw the crank in the block & indicate the bore to see if you have a problem... Or a joker...
Alright, just got the ID done,
At this shallower position, I got .006" max
This deeper one I got .002" max, more like .0015"
Both I'm estimating are 30 degrees from perpendicular so the actual runouts are higher than what I saw.
If I go deeper the gauge will be at 45 degrees and will probably deflect, but it's better the deeper I go so far.
The OD runout I'll get here soon, good call! Hadn't thought of that one
