Magnum 408 cam
chaditotx
Texas
Edelbrock Magnum Heads, mild porting/clean up
2002 Roller block
RPM Air Gap intake
408 Stroker kit
1.5 Crane Gold
1971 Demon (3200lb)
3.91 gears
Compression 10.5:1
727 with reverse manual and 2800 stall
NOT a daily driver. Cruise and strip
Originally, my cam choice was a hydryaulic roller xr286hr from Comp. for a stock displacement Magnum. I came across a RIDICULOUS deal on a Scat 408 stroker kit a couple days ago (internally balanced, forged pistons and rods ) and I was all in. So my knee jerk reaction was.... "why not more cam?" I returned the XR286HR cam and ordered the XR292HR cam. I know the cam says pro-street , 4.10 and 3k stall BUT its spec for a 360 in the recommendations. Wouldn't a 408 soak up a bit of that agressiveness? Anybody running one?
20-814-9 - Xtreme Energy™ Retro-Fit Hydraulic Roller Camshafts
Yes and no. IMO, it'll be a nice fit and a lot of fun. I'm not to sure how that converter will play out.
And this is the problem with changing the plan. It may end up costing you a lot of money. It already costed you some with sending the cam back.
Hey Rumblefish360! The voice of reason.... Agreed. I'm hoping to recoup a little of the money with the sale of the 340 in the car now. I weighed the cost of the overbore, and the cost of the kit against buying bearings, rod bolts, good rings, resizing rods if needed, and missing a weighted flexplate ($189 from Hughes) for a stock type build. BONUS was forged rods and pistons and a steel cast crank and internal balance. Supposedly the converter was purpose built for a 340 running a 727 and 3.91 ... so I am hoping it doesn't get too loose with that 408 torque wrenching on it. After the sticker shock of building a Mopar ANYTHING I'd like to hope I don't have to buy another. On another note, the cam change was a simple return at a local parts house. They didn't even notice I'd used a 20% off coupon online, or got a $10 gift card for every $100 I spent ;) and took it back full price.
Thanks bro. To many years of scrimping and saving to get a new part. Best advice I can give to anybody is make a plan and stick with it. Changing it becomes expensive and money to throw away like the U.S. Government does on problems (real or perceived) I can not do. LOL!
The extra torque of the 408 will increase the stall speed of a converter. How much is the question.
Yes the increased displacement will eat a little cam duration and it will (kind of) eat up some of the agressiveness of a larger cam.
But how much of this change work out together and will it be acceptable is an unknown to me. I have been running manual trans cars forever. My auto trans cars are normally very mild builds.
2002 Roller block
RPM Air Gap intake
408 Stroker kit
1.5 Crane Gold
1971 Demon (3200lb)
3.91 gears
Compression 10.5:1
I agree with rumble, But...I think it'll work out by the skin of its teeth.
These things make a lot of torque and like right now. The convertor , street wise, is short by 400 rpm....but most important with choosing cams, is gears....and you do have at least a 3.91 gear. Though the combo is a hair wider then you'd want, I say run it. I bet it hauls ***.
