magnum force tubular A-arms...opinions???
dusterdan
Sublime Member
La Mirada, CA
hey guys, i'm looking at purchasing a set of these tubular upper control arms with ball joints installed for about $300; anybody have any expereince with them or do ya'll recommend another brand? thanks i appreciate any input!
I had a set on my Dart did not care for them as they seem to be a race only kinda deal . The solid bushings give a harsh ride with very little movement.I sold mine and went back to stock upper a-arms.I wouldn't recomend them for a street driven vehicle.My.02
Also you have to grind or cut away the reinforcing tabs where the arms mount to avoid interference.
World suspension has a reasonable set simular to the stock brand for $150.00 bucks on ebay. Only problem is they are made in china. If it's not a daily driver it's the most reasonable way to go. Good luck!!
bought a set of RMS a month ago or so....easy bolt on ....and alignment...
I put a set of them on my car in 08 and they work great except they do transfer a little more road noise due to the heim joints but they react quicker for lift so they have an advantage for racing. Mine went right on with no cutting or grinding needed and aligned easy.
thanks for all the opinions guys!!! what is it about the "rms" arms that are advantageous over the magnum force arms? My duster is lowered and is spiritedly driven around corners but no means an autocross car at all. I'm staying away from stock upper A-arms because of the poor geometry caused when lowering a torsion bar equipped vehicle like my duster...
Gators340, i did a search and their website wasn't responding but in their ebay store World Suspension only has a few items listed for a duster, control arms not being one of them. would you perhaps post a link as to where you found your info? $150 for control arms is worth checking out....i want to research the quality thoroughly because this is an important aspect of my whole front end LOL thanks!
I've had a set of non-heimed uppers from magnumforce on my street driven car for years, no complaints at all !!
