bradr440
Active Member
Sorry if this has been discussed to death but I can't find the answer. I see Hughes says you have to clearance the pushrod tunnels to put Iron Rams on an LA block, so do you have to do this with factory Magnum heads on an LA block? This is an LA block with a hydraulic flat tappet cam. Thanks
