Nick M.
Do i have the wrong bearings? 76 360 block bearing p# 4999m 10 under main bearings crank was ground 0.010 Crank binds on the thrust surface when set into the block, is the thrust surface supposed to be 0.010 under as well as the rod and main journals? This the first chrysler i have attempted to build, have done many chevys and have never encountered this problem before...bad machine work? bummed was hoping to assemble the bottom end this weekend
