This is an article on another Mopar web site but is very informative on 8 3/4" Mopar rears. Take the time to read it and it will enlighten you.
Moparts on the Web - Main Index
Even if the wheels spin different directions, can I still spin the wheel one rev and count the turns of the driveshaft to determine the ratio?
7milesout
OK. I'll keep that in mind.If you decide to go with a clutch type make sure you add 2-3 bottles of mopar friction additive
Do you think that might be a lil much? I don't know what the consequences might be of running too much. I guess it kindof depends on the size of the bottles, but I only run one or less.If you decide to go with a clutch type make sure you add 2-3 bottles of mopar friction additive
