Since all my luck is bad luck, I figured that Friday the 13th would be a good day to get the car done, maybe it'd work opposite.
The car moved out of the garage under it's own power. Me & my neighbor spent about an hour beforehand bleeding the brakes, there was a ton of air in the lines. There's still some air in there, it takes a real lot to get it stopped. But it's better than it was!
I'm gonna bleed the brakes again tonight to try to get the pedal up higher and hold a little better.
When I'm standing on the brake, I can bring it up to about 3000 before it starts to pull forward. The car seems like it has a ton more power, but I think that's just because I haven't driven it in so long. It does sound better, and pulls a lot harder. After I warmed it up and broke in the brake shoes I did a few line lock tests... The brakes didn't hold all that well unless I pumped them first. But once I got them to hold I brought it up to 3000 with the line lock on and dropped the hammer. The car nearly got sideways and left two long black strips out in the street.
W00t!
W00t!
