Man Dies After Crashing ’70 Plymouth ‘Cuda Into Telephone Pole
Might be. any maybe a reverse valve body. BUT... My point was, it doesn't matter, and it STILL doesn't matter.
Just so you know, I'm a stickler for details. You said it could be in 2nd or 4th. If it is an auto, than it's either in 1st, or 3rd.
Fact do matter. So, either way you were incorrect. It' either in 1st or 3rd. And likely, the shifter was moved several times during the crash.
Maybe after shearing a pole at triple digit speeds, the trans, mounts, and linkage are so misaligned, nobody can say definitively what gear its in.
And to add to his last mistake, I believe the utility will charge someone for the pole replacement, if possible.
