Man's Guide to Tools
6pak2go
Mesa, AZ
Apologies if this has been posted before. Made me smile...
DRILL PRESS:
A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, denting the freshly-painted project which you had carefully set in the corner where nothing could get to it.
WIRE WHEEL:
Cleans paint off bolts and then throws them somewhere under the workbench with the speed of light. Also removes fingerprints and hard-earned calluses from fingers in about the time it takes you to say, "Oh damn".
SKIL SAW:
A portable cutting tool used to make studs too short.
PLIERS:
Used to round off bolt heads. Sometimes used in the creation of blood-blisters.
BELT SANDER:
An electric sanding tool commonly used to convert minor touch-up jobs into major refinishing jobs.
HACKSAW:
One of a family of cutting tools built on the Ouija board principle. It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes.
VISE-GRIPS:
Generally used after pliers to completely round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand.
OXYACETYLENE TORCH:
Used almost entirely for lighting various flammable objects in your shop on fire. Also handy for igniting the grease inside the wheel hub out of which you want to remove a bearing race. It's best use is for igniting new seat covers.
TABLE SAW:
A large stationary power tool commonly used to launch wood projectiles for testing wall integrity.
HYDRAULIC FLOOR JACK:
Used for lowering an automobile to the ground after you have installed your new brake shoes, trapping the jack handle firmly under the bumper.
BAND SAW:
A large stationary power saw primarily used by most shops to cut good aluminum sheet into smaller pieces that more easily fit into the trash can after you cut on the inside of the line instead of the outside edge.
TWO-TON ENGINE HOIST:
A tool for testing the maximum tensile strength of everything you forgot to disconnect.
PHILLIPS SCREWDRIVER:
Normally used to stab the vacuum seals under lids or for opening old-style paper-and-tin oil cans and splashing oil on your shirt; but can also be used, as the name implies, to strip out Phillips screw heads.
STRAIGHT SCREWDRIVER:
A tool for opening paint cans. Sometimes used to convert common slotted screws into non-removable screws and butchering your palms.
PRY BAR:
A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50 cent part.
HOSE CUTTER:
A tool used to make hoses too short.
HAMMER:
Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate the most expensive parts adjacent to the object we are trying to hit.
UTILITY KNIFE:
Used to open and slice through the contents of cardboard cartons delivered to your front door; works particularly well on contents such as seats, vinyl records, liquids in plastic bottles, collector magazines, refund checks, and rubber or plastic parts.
Especially useful for slicing work clothes, but only while in use.
SON OF A ***** TOOL :
Any handy tool that you grab and throw across the garage while yelling, "Son of a *****!" at the top of your lungs. It is also, most often, the next tool that you will need, and at times must be retrieved from across the road.
Ah yes,the power of Murphy's Law......Got to learn somehow, injury makes it stick in your memories.
Seen that before, but always worth a laugh. I just had a big fight with the toolbox on the trailer project. Turns out the frame underneath was not NEARLY as thick as I thought and when the drill broke through, the lid started waggin' around and beat me in the eye and cut my nose. Yeh. I used THAT kinda language, LOL
lol real nice...know a few people that should read this....
wow brings back some painful memories I would bet most of us have at least one of these happen
Ahhh **** my ribs hurt...from laughing! That's so true but still......FUNNY now to figure out how they did it! LOL
NICE one, I ought to come up with a way to make that a shop poster!!!!!
this was awesome to read. made me laugh my *** off because i had a moment in the garage the the other night that im still laughing about. was pulling a steering box out of a car with engine out and the bolts were so stupid tight that it broke my 3/4" drive ratchet. so i used my 1/2" drive ratchet with the jack handle as a cheater. well it let go and smacked my knuckles against the frame rail and hurt so bad i couldnt even utter a swear word. i was so pissed i cocked back to throw the ratchet into the woods behind my shop. i dropped the good one and picked up the broken one and threw it out into the woods. after i threw it i had a moment of self reflection and just sat and laughed at myself so hard the girlfriend came out and checked on me. prob gonna remember that for rest of my life.
Truer (is that even a word) have never been spoken. We can look at our hands and often remember how the most significant scars got there....
If someone were to clean out the bushes across the street from my folks home they no doubt would find some nice tools....and be able to sell enough scrap metal to build themselves a nice car....
