Please help!! This problem is keeping me from finishing my car. Im installing a map light harness into a 71 duster that did not have the light package. Have the map light, ashtray light, and glove box light. I don't have an ignition light. All wires are connected except a yellow wire that ends on the far left and middle of the harness and a pink wire that ends on the far right of the harness with a male connection and an L- shaped female.
Ashtray light works when headlight switch is on OK.
With the glove box light housing grounded and map switch on glove box light works. When either door is opened, the gb light goes out. Map light and dome light do not work.
I dont think this is the right thing to do, but when I ground the L-shaped female pink wire, and map switch on the map light and dome light are dim. Open either door and the map light goes out and dome brightens. GB light does not work.
Not sure if this is relevant, but the entire instrument cluster is out of the car and the map light harness is just laying in the dash while I test. Also, the two yellow wire connection in the center of the harness connects to the main wiring harness in the dash of which one of the connections is always hot. The yellow wire from the hot side goes to the map light switch.
An ideas? Thanks.
An ideas? Thanks.
