MtNemoMopar
In the doghouse
Does anybody sell rebuild kits from here? I need one for a 2660809 casting.
NAPA has it online. Thanks for the tip. My car is a 69 Swinger, 4 wheel drum. My master has the holddown butterfly with a center bolt.
It might work, but better to get an optimal MC, since they are cheap. Disk brakes usually require more hydraulic pressure than drums, so most either use a vacuum booster or an MC with a smaller bore (7/8" or 15/16"D). Disks also tend to draw more fluid so the disk reservoir is usually bigger. You can use almost any MC. Many here use a more modern aluminum ones, using a 2 to 4 bolt adapter plate. However, best to copy others since you can run into problems with the pedal rod length and such.I have this same master cylinder, but i have discs on the front.
Is it safe to use it, or should i get proper one?
