Thank you! Thats good to know! I'll go ahead and pick up a Power disc/drum master for a 74 Dart. Are the cheap Reman. Cardone ones any good???
There is nothing wrong with the Cardone MCs. They are a good value, if you can find the right application.
To "wracks71": What is it about the factory MCs that "sucks"? That they aren't painted bright red with a logo? The fact is, there is nothing about any correctly-sized master cylinder that can improve your braking performance, no matter what it costs (the braking is done at the caliper & disk, and most of all at the tire & road) -- the only benefit from an aftermarket MC is that an aluminum body will save weight.
Someone told you to get the 15/16" bore. This is good advice. The slightly smaller bore reduces the pedal effort. The 1-inch-and-over bore sizes without power assist will create a much stiffer pedal than most people are used to -- so stiff that some people will have a hard time locking up the brakes.
