'64 Cuda
Can somebody give me a ball park figure for the maximum valve lift a stock J head will handle before you need to cut down the guides? I seem to remember reading way back that it was around .510", but I'm old, so my brain doesn't work as good as it used to. :sad1: How much clearance is required between the top of the guide/valve stem seal to be safe?
Another question. Does anyone know the proper name, or a part number, for the "spider" on roller cam engines? I've tried searching Mancini's site but can't find it. I found the tappet alignment yokes & the lifters, but no spider.
Seriously, I think these are just a bit bigger cams than I need with what I've got, but now I am wondering how they would work with Edelbrock heads. That would bring my compression ratio up to the mid tens, which might make these cams a bit more suitable but I'm still a bit leery. The price on the roller stuff is good enough that I could probably buy them & sell the camshaft & still come out OK. Did you look at the Thumpr roller cam? It's close to specs of the Comp roller cam. It's listed as having an RPM range of 1900 to 5600, which sounds like a streetable profile. It's also just a bit more duration than what you recommended, but a little can make a big difference.
