Idaho
- Joined
- Oct 17, 2006
- Messages
- 2,595
- Reaction score
- 275
I've made my brain hurt, sorting out the measurements for my differential width, along with wheel and tire combo. I'm mini-tubbing my 69 Dart so the 14.5" of space between the 1/4 panel lip and the frame is available.
I caught myself making an error that could cause a major headache and thought I might save others a potentially costly mistake in this process.
I'm planning to use 10" wheels and initially made a drawing using 10" as the wheel width. I had determined I needed 1.25" space between the tire and 1/4 lip in order to allow a low stance without having the tire contact the 1/4 panel up higher where it projects inward more than the 1/4 lip. So placing my chosen tire on the drawing at that distance gave the results on the lower drawing. The tire I chose happened to fit with 1.25" to the frame as well.
The error comes from not using actual outside measurements of the wheel. The result is a wheel mounting surface that is off by a half inch to the outside. That error would result in a wrong differential width. It could also result in ordering wheels with the wrong backspace.
Because little mistakes matter, I believe if one will be narrowing the differential, it is safest to get wheels and tires first, make a spacing device of some sort (like an adjustable axle between them) to accurately secure them in the wheelwells and take a measurement between the wheel mounting surfaces. However, the drawing is still needed in order to get the wheel, tire and backspacing correct.
I called the wheel manufacturer to get the outside measurement of the wheel since this is never specified.
Another potential error could happen in measuring backspace. I found conflicting sources online. One advised measuring from the wheel inside the outer lip (where the bead contacts). This requires cutting a straight edge to fit inside the outer lip. The proper way is to the outside of the wheel lip.
