Mechanical six pack idle circuits
68 HEMI GTS
in the garage
i posted some of this over on for B bodies only but thought it may be of interest for some guys over here also as it seems a lot of the “A” body guys run the 4782 & 4783 direct connection or “hustle stuff” carbs. In my case I’m running a set on a 511 low deck with Indy SR heads and solid 260/266 @ .050 camshaft. I decided to run a 4412 “500 cfm” center instead of the anemic 4782 center. The issue I experienced was the unadjustabe outboard idle circuits just did not supply enough fuel at idle on my low vacuum big cube engine. My first “fix” is I went up .010 on the weep holes that supply the fuel. Unsatisfied with that I ended up adding full idle circuits as well as adjustable idle bleeds. While this was a bit involved, I’ve been able to really dial in the cabs to have excellent A/F readings at idle & cruise while maintains great drivability and WOT performance.
Tools needed;
Numbered drill bits
Small harbor freight drill press
Center punch
Some QFT/proform metering blocks ( I went without powervalves although you could add those too if desired).
For adjustable air bleeds
8/32 tap & 8/32 brass set screws
First step is identify where we need to add the circuits
The main body face is predrilled although it will need to be drilled slightly deeper
This will be where the idle circuit passes through to the base plate
Origional weep holes. I plugged these with brass tube and epoxy to kill them.
Time to fire up the drill
As you can see this just needs touched up with a hand drill
These will need to be hand drilled, this is your new idle fuel supply. Steady hand and take your time.
I went with these blocks because they were the cheapest quality block I could find
High idle feed restriction. Seems to be a topic of debate. I like to run them lower.
Will relocate to here
These blocks have extra emulsion, don’t need that so I plugged the middle.
Ready for assembly
Still unable to obtain my desired A/F target I pulled the carbs back down and added adjutable idle bleeds to all 3 carbs
Set screws installed, you can drill and swap blanks till you get what you need.
Once I got it where I was happy I relocated the supply line and insulated the fuel lines, I have wrap too insulate the fuel log for long drives. It just looks like crap so I’ll leave it off for local cruising.
With some tuning and tweaking she’s right on. I would caution that if you plan on going off the deep end that you have a quality A/F meter as well as a good understanding of carburators and what you are affecting with your changes.
How do adjustable bleeds "adjust?" I've no experience with 'em
you have 4 air bleeds on a normal 2 circuit holley. 2 outter bleeds control air to the idle/transfer circuit while the inner bleeds control air to the main circuit. You adjust them to fine tune your a/f ratio along with some other factors.
No I mean how do they adjust mechanically? Do they have interference fit like some rockers and you just turn them like needle valves , or do you pull them and change them like fuel jets or what? I'm 72, never screwed with 'em. No doubt you have some awesome stuff
no, in this case I drill them different sizes with numbered drill bits and swap them out till I get what I need.
Thanks. I've never screwed with these "in the day."
Wow I only just seen this and I'm very impressed indeed!
I have a 71 GTX that I'm gonna run in UK Superstocks.
It will be a 512 with a six-barrel set up.
Now I know exactly where to set my sites!
In the high tens lol:thumbsup::thumbsup::thumbsup:
One thing I should add to the thread as I did some intake work that really helped out the drivability and distribution on the bigger cube engine. Idle quality greatly improved. I believe it’s faster as well but I changed a few things so I can’t quantify a number.
Thanks again Nevin! Stoked for the info, advice and links.
Cant wait to play with Six Packs again, its been over 30 years since I have three 340 Six Pack setups at the same time to mess with!
Cheers!
