Member number?
The easiest way is to move your pointer to your avatar name,you will see at the bottom bar the last #,s will be your member #.I believe your,s is 3740.Check it out!
or right click on the your member name and go to properties and the bottom number ends with the user number. Mine is #10211
i did what you said so i take it my number 8715 is that right??
I just joined :D 66340SEDAN joined 13 members after me witch made him 3.640th member :D and me 3.635th .
