doogievlg
Is the tank vented?
Tank is vented so no vapor lock
Is the tank vented?
Before you rush out for a pump, I suppose you proved your supply line was clear and the pump was not sucking air..........
Don't go out with this 'captain' again. Doing so may turn you into a statistic. Oh, if you should, make sure your life insurance policy is good.
Some older boats have galvanized tanks and if that is where the metal is coming from that tank is not long for this world. A boat, a bilge, and gas fumes =kaboom. Not something to play around with. One little spark and the boat blows apart. A small fuel leak will do it.
If you don't get out on a big lake, like one of the Great Lakes, you should be ok. I was out on the BIG LAKE once, Lake Michigan, when the boat kept dying on us, and there was a NE wind with 8 foot rollers. We were in a 18 footer. The only time I was concerned on the water..... Never went with that guy again. But it is up to you. I have gotten to the point where risk taking is not something I like to do anymore, at least at my advanced age of 59. LOLWhy do you say that? Nothing wreckless is happening, just mechanical issues.
