Mini tub tips...
68383GTS
East Peoria,IL
I am going to mini tub my 67 Barracuda.Any tips before I start cutting.Pics also may be a big help.This is the first time I have done anything like this.Looks fairly simple,but the seat and sail panel brackets maybe be a pain.
Thanks,Jim
Any pics. on how the rear seat mounts may help too.I bought my car as a basket case and I am not really sure how the seat mounts.Does it just hinge to the brackets on the tubs?
Jim
Buy the best spotweld cutter drill bit you can find.This will help make your job quicker.
Go to the search function and type in Minitub,should be lots of info with pics.Good luck Jim.:D
Stretch the forward portion of the rear wheel opening 1.5" for big tire clearance.
If you're gonna mini tub you definitely want to do this while you are in there.
