Misc abody stuff 67-74 (more added)
Sedanman
67-9 Valiant specialist
chicago Il
I'm cleaning out some more stuff I don't need
Ps-manual steer adapter,requires a manual coupler $50
Kframe to rad support bracket with bolts $10
Small block kick down & shifter linkage,some column shift & console $40 all
factory rear exhaust hanger,weld on type $10
small block oil dip sticks & tubes,long ones are truck & other is car $20ea
68 valiant guages,no bezel,speedo works $25
67-9 black visors,1 has had the seam come loose but in nice shape if you can sew $20
68 valiant pass fender used but has NOS # visable $175
I'll ship the small stuff but prefer pick up on large stuff. Feel free to make an offer + ship from 60108
The fender was used on a 67 & is the reason for the screen & bondo. It was just to fill the marker hole
i will take if that includes shipping
I forgot about these too. Brand new brake lines from Fine Lines from the master to the prop valve on PB cars with factory BBP disc conversion $20 obo + ship
Trunk light wiring set up $10
under dash floor light set up $10
new electronic volt regulator & wiring $20
2 speed wiper motor $10
73-up new spool trans mount nib $10
66-9 turn signal switch with plug cut off,no broken tabs $10
2 front fender support brackets $20
steering column support bracket bolts,plastic inserts & ground wire $5
black column wiring covers,the metal & the plastic round tube $10
VDO guage pod includes volt,oil & water guages $30
chrome brake pedal pad $10
2 70's guages removed from a cluster I stripped out 120-150 (301642),-40-+40 (301643 $?
Shipping isn't included & pick up is always welcomed
67-72 trunk floor gas filler tube seal $10
4 66-74 bucket seat weld in support plates $25
engine mounted heater hose support bracket $10
glove box lite harness $10
turn signal arm $5
2 outside door handles decent driver chrome $20
small block intake water outlet $5
chrome valve cover breather (twist on) $5
7 plastic window crank washers $10
fuel sending unit lock ring $?
interior light lens cover $?
battery top hold down bracket $?
metal inner rocker wiring covers $10
Heater hose support bracket and the 2 new brake fluid lines shipped to 29642
Just pm me with payment details. Thanks
suprised you still have that PS to manual adapter, those seem to be made of gold at 150+ new...bump
the brake lines..... i have a 67 dart with the 73-76 disc swap and the prob valve/metering block from 74 dart with disk. are these lines for that exact application?
