Misc Parts for Sale and Wanted.
Matt Selwa
Active Member
Rating - 0%
0   0   0
Time for Spring Cleaning I have the following parts for sale:
-22" Radiator for an automatic, pressure tested and sides brazed in place, painted ('6 $80
(removed from a '68 C-Body, but will fit a later model A-Body such as
my '71 Duster - but it would be more correct for a '68 Dart since it has
the curved top surface by the radiator cap)
-Schumacher Motor mounts to install a 273/318 small block in on a /6 K
member $85 --> $75 (dropped price since I suspect most people will
want the set to swap in a 340/360 - will not fit later style spool motor mounts, they worked
fine to install a 1968 318 into my '71 Slant Six Duster)
-Headlight bezels for a '71 Duster Grill good shape $20
-Grill for '71 Duster, multiple cracks and broken pieces - possiblely use
with your broken grill to make one good one. $20
-Nice set of exhaust pipes with straight thru mufflers welded on the pipes.
Flanges welded on pipes to bolt to the headers, with dumps in front of rear
axle. This would be a good set for a street/strip drag car. (2.5") $100
Regards,
-Matt
What diameter are the pipes and what mufflers are mounted?
Are they used?
more info on mounts sb on \6 ? Spool type ?
I have a 1975 \6 k to put a 273 on
Are they used?
The mufflers are similar to flowmasters and are pretty loud, but I do not know the manufacturer of them (they were installed on my Duster when I bought it). The pipes are 2.5". The pipes and mufflers are used, but clean with no surface rust.
Regards,
-Matt
Hi,
I am interested in the grille as the one I have is in need of a couple of missing sections. Will you ship the grille? Let me know where to send payment including shipping.
Thanks
David
Just so everyone knows... I couldn't use these...
-Schumacher Motor mounts to install a small block in on a /6 K member $85
Seems they are for the earlier \6 K
cheers
(Updated descriptions for the Radiator, motor mounts and exhaust)
-22" Radiator, pressure tested and sides brazed in place, painted ('68) $80
I need the following parts:
-Manual Steering Shaft Coupler
-Dash Pad for a '71 Duster, any color ok since I am willing to dye it black,
but it must be in nice shape with no crasks.
The parts are located in Newaygo, MI and I am willing to package up any of the parts and quote shipping costs.
Regards,
-Matt
Hi David,
Attached are some pictures of the grill to make sure that it is what you want. Please note: the turn signal plugs changed in '72 so this grill will fit '70-'72 but you will need to change over the plugs if you are installing it in a '72 (I found out the hard way when I went to install my '72 Sharktooth grill in my '71). I will send you PM with the shipping costs and my address shortly.
Regards,
-Matt
Attached are some new pictures.
Couple of additional items include the following:
-A set of 318 exhaust manifolds, see pictures for the P/N's. Blasted and
painted with high temp paint, just needs to be cured. $45
-Summit aircleaner, 14" diameter, 3" tall for 4 bbl. $15
