73SlantSwinger
Need some advice on what direction to go with this thing. 71 Swinger 225 40K miles car was changed over to 2bbl setup before I bought it but it had a cheap aftermarket 2bbl on it. Previous owner supplied the Carter BBD but it needed a rebuild. I had it rebuilt and put on but now the motor shakes and misses. It idled a lot better with the other carb on it, although the idle was a little low. Weird thing is it drives down the road nice and pulls good, don't feel any missing until it almost comes to a stop slowing down or idling still. Throttling up you can hear the miss and the motor shakes really bad. Pulled and checked all the plugs (NGK ZFR5N) all were a tan color. Cap, rotor, plugs, coil, wires are all new. Timing checked, valve lash adjustment done, vacuum lines all look brand new. I even pulled a wire off each plug when running to see if there was a difference in each cylinder, strange that the back two cylinders by the firewall didn't change sound at all when pulled off. Should I check compression next?
