70DusterBob
Hey,
I am new to this forum. Looks exciting with all the areas to post in and lots of people here!
Yesterday I was driving my 1970 Duster/360 with Electronic Ignition, (basically stock from later year models) and it started missing here and there but run fine between misses, like once every 5-10 miles. Then it started sputtering, longer periods of missing every 5-10 miles, but would run fine between episodes. It started getting worse, as in more frequently and sputtering longer, but still ran fine between sputters. Then it just cut off, for a good 3-4 seconds. Sounded like when your running out of gas how it sputters, but is mostly not firing. I was driving 60 so it started running fine again before I came to a stop. Then it drove fine for a good 10 miles, only sputtered maybe 3 times in those ten miles, then it cut out on me again. Then it ran fine for a while, sputtering every 5-7 miles or so, but I barely made it home. I made it 20 miles after the last cutout and I got it home and in the garage, but I have no idea what to look for or what it could be. I doubt it is a fuel problem, though I guess it could be, I'm thinkin' maybe the spark plug wires, but it doesn't make sense why it would be sporadic like that, then run perfectly fine between missing. From the first miss to the first cut out was approximately 90-100 miles. Then I made it probably 30 more miles with one more cut out to get it home.
Any ideas? I would love some help on this one!
Bob
Bob
