Ok , so I go to install the Cope Racing 727transmission in the 416 68 Barracuda and discovered another snafu. On the drivers side lower 7/16 bolt that bolts the block and trans together, there is no hole in the transmission where the bolt that is suppose to go from the front of the engine into the trans? It is solid aluminum. I can drill it out and tap it for the bolt but I was wondering what is up with that? The 416 uses a 68 340 block and I don't know what year the SB 727 is. I'll check for a date on it tomorrow. Anyone run across this before?
