rustytoolss
will modern challenger wheels bolt on to a 70'smopar ?
bolt pattern is different and depending on the exact 70's mopar, the offset may be an issue.will modern challenger wheels bolt on to a 70'smopar ?
Agreed.You'll find that for most applications the modern wheels have way too much offset (too deep on back side of the wheel). This tends to cause clearance issues.
0lus at american muscle the mustang rims have the correct bolt circle.
They are the right bolt pattern but the center bore is smaller...ran into this issue with the 17x8s I'm running. I had to use a rotary bit to open up the bores enough to fit.
About the only late model alloy wheels that have the correct spacing and pattern are jeep wheels, and that's changed/changing. Just buy the right wheels. That being said, good luck finding an online bolt pattern guide that is correct!
Hub concentricity isn't your thing, is it?
I spent 8 hrs doing all 4 rims, test fitting, measuring and sanding. 100% perfect fit in my case, no vibrations at 90mph.
